Which anvil?
Chris152
26 Apr 2017
Cardiff
We're looking to do a little forging and plenty of panel beating and have started looking for an anvil with holes for accessories. I guess somewhere from 30 - 50 kg would be good.
What are the differences between forged steel, cast steel and cast iron anvils? I've done a bit of reading but am still not at all clear - here's a summary I found:
'Cast steel- weldable, malleable, and very sturdy for an anvil.
Cast Iron- brittle, and not so good for an anvil.
Forged-weldable, very strong.'
And, is it better to go vintage, used (in general) or new? Do older ones come in all three flavours?
As examples, Vevor have a 30kg one, forged steel, for about £85 and it gets good reviews;
they have a 60kg cast steel one for £230 (tho the details say it's 'drop-forged, high-grade steel - is that cast?);
and ebay has lovely vintage ones (they tend not to state manufacturing method) for much more money.
I'd appreciate any advice you can offer.
Thanks, Chris
eta - I've also read that cast steel makes less of a deafening ring. Is that right? - noise matters as we have neighbours!
Cast iron aren't anvils as there rubbish. That leaves cast steel and wrought iron with a tool steel top.. brooks are great cast steel anvils. They ring loudly but are superb. Most vintage anvils are wrought iron. Peter Wright are probably the best. Wilkinson, Mousehole etc. Are older.
Thanks, Chris
Cast is pouring molten metal into a mould. Drop forged is usually using a dirty great mechanical hammer or a ram to squash the metal into shape, and results in a much stronger product.
Thanks for the replies all - I'm going to work through the links later and get back to you.
Buy the best you can afford.
At the big workshop we have 2. Both 3 feet long.
Both cast, one of iron and the other of steel. Both strapped down to a large stump of English Oak.
The iron one was a left over from the farms old forge, very good for rough hot work.
The steel was liberated from a Scrap yard, cleaned up and is better for doing finer work.
We have two bench top ones, one shop brought and the other from a length od rail track.
There are two types of cast iron anvils:
1. Old American ones with a spring steel plate fire welded to the top. They tend to crack with age are very difficult bordering impossible to repair but as long as they least they are decent usable anvils. Few were imported to Europe. They are no longer made and haven't been made for decades.
2. Anvils made entirely from cast iron. Older ones are usually of Eastern Bloc origin and newer ones are often Chineese whatever they purport to be. They are only good for garden ornaments and buoy anchors. Completely useless as anvils. The face is too soft and after a while they crack.
Cast steel anvils are very good. They last long and once they are worn out after wearing out two or three blacksmiths they can usually be repaired. Some are easy to repair and some difficult. It depends on the exact composition of the metal.
Forged iron anvils without a hard face is the oldest type. All that still exist today are badly worn out but they are easy to hardface using a 200 ampere stick welder and some special hardfaciong rods in the 5mm variety.
Forged iron anvils with a face of spring steel fire welded to the body are very good. When they finally wear out efter wearing out two or three blacksmiths they are easy to repair with hardfacing rod.
My oppinion is that 40 kg is the minimum size for serous forging. 60-80 kg is way better. I forge on a 40 kg anvil while hoping to find time to repair the 80 kg hard faced forged iron anvil I found at the scrap yard and bought for 30 or 40 euros. It needs a new horn and a new face.
Well, after lots of searching and reading/ watching, I'm inclined to think the DIY route is best for us, tho still not 100% sure how to go about it.
Those threads you linked to Sideways - they have some really good ideas. I've managed to source a few lump hammers, an old sledge hammer and some cold chisels for under £20 (not collected them yet), but all look like they could be made to lend themselves to sheet metal shaping (dolly-anvil type things) with a simple forge and some welding.
But we still need something to hammer the shapes onto and the nearest 'un-anvilised' (pre-cleaned up ones on ebay) rail track I can find is in Taunton, which is too far all things into account. So maybe we could go with this 'cheap' anvil:
https://www.ebay.co.uk/itm/39417929...%3D|ampid:PL_CLK|clp:4429486&epid=19029492476says it's drop forged, but no mention of a hardened top (any thoughts on that?). I guess we could get it for 80.
There's a splendid 1 1/4 cwt Brooks on a stand nearby but it's at auction and already £200, plenty of time to go.
We like the idea of making for ourselves, but that Vevor one looks half decent and probably not much more expensive than setting out on the road in search of railway track elsewhere. The purpose of the anvil is to make and hopefully hold the dolly-anvils we'll make for sheet metal shaping (for car restoration), and should be useful for hammering in general.
Many thanks for all the replies, really helpful.
I suspect he meant differences in use rather than in manufacture.
I actually meant manufacture, Phil - I was getting confused by the suitability of anvils made by different methods, and probably was confused in what I wrote :)
hope u liked the vid....
I just love metal......oh, and wood......
My preference is wood, but since my lad decided metal would be his career, I've lost the garage and key wood kit and replaced it with a lathe, mill, welders and a rotten mg midget. Happy days! (Actually, I'm really enjoying learning new things - not that I was anywhere near stopping learning how to shape wood...).
If I am not reliving high school shop classes and only imagining them, the sheet metal workstation was a thick plate (1"?) about 1' x 3' long roughly mid thigh high with Hardy, Prichard holes, etc in it. The different sheet metal stakes/anvils were placed and used as needed, then pulled when done. There was no traditional anvil anywhere near it. If you had the stakes you could have a sheet of steel plasma cut for them and legs welded to the underside.
https://www.ebay.ca/itm/115936240374?hash=item1afe56a2f6:g:tEQAAOSw0PJlIX4tStakes and Stake Anvils : anvilfire Anvil Gallery Halfway down the page.
I'd not seen one of those Pete - I guess it's kind of like a smith's swage block can be used for holding the stakes. But we still need something to shape the stakes onto (once we've made a little forge, of course), and the best option looks like a cheaper anvil in the absence of railway line? We'll keep looking for alternatives before hitting 'buy' though.
I suspect there might not be enough “mass” in it for proper smithing work, but I use a lump of RSG as my anvil and for me it works just great, Im sure I did see somone on utube or the net that had through bolted a couple of oak blocks into the web to beef it up further, the top and bottom are tapered so it would be easy pull them in good and tight, made it look good and workmanlike too.
