Hi
This is my first post so please be easy on me..
I used to earn my living as a furniture maker but had to retire due to health issues. I was a one man band and like most woodworkers built up from basic kit to in the end a rather decent Felder combination - so I guess I was a little spoiled.
I'm in the process of helping set up a small workshop for my son. We're utilising an old outbuilding which has decent power/light and a concrete floor but otherwise is pretty damp and shoddy.
I've got an old Inca bandsaw which is still going strong after 20+ years and a decent sent of hand power tools but other than that we're starting from scratch.
Our first purchase will be a 10" table saw with a budget of up to £700ish. I've looked into the Record TS200C which looks a decent bit of kit but I'm a bit worried about the cast top in our damp old shed. The other saw that took my eye is the Metabo PK 255 which looks to have an ali deck and is lighter so easier for shifting out the way in a small space.. Other than those I've also considered portable site saws (not great for crosscutting but should be OK for ripping rough stock) namely the Bosch GTS 10 and the Makita 2704 - of these the Makita looks the more complete with a better cutting depth and width and a crude outfeed support - not sure about the brush motors though. I've also considered the Scheppach TKU4000 - a rough and ready site saw but which has an induction motor, might survive a damp environment well and should be good for ripping down with a full 4" cut but only a small width capacity without an add-on side extension.
Any thoughts on any of the above would be greatly appreciated. I've seen reviews of some sort or other on all of the above except the Metabo PK 255 which is the most expensive but looks OK spec. wise.
I really haven't got the space (or strength) to move a very large cast iron lump around the workshop so size and weight wise the Record or Metabo are probably as big as I want to go and if I'm honest the Record is heavier than I'd like but should be OK with the wheel kit.
Many thanks in advance
Tim
Tim
