Proposed workshop build
Motar is mainly used to keep the bricks apart not glue them together. A NHL 3.5 mix will be a direct replacement for a cement mix and is specified quite often nowadays for face work . You can get it in builders merchants easily or get bagged premix online. It's best to mix dry then add water to give a slightly dry mix ,rest for 5 mins then mix again to give the right consistency . No plasticizer or additives. It's stickier than cement so you may have to scrape the back of the mixer halfway through.
Engineering bricks have better strength and can be used where they will permanently wet. If neither of those apply then normal bricks should be ok.
