Milescraft TrackMaster
Wood Workers Workshop
UKW Sponsor
16 Nov 2021
Threshing Barn, Upton-upon-Severn, Worcs WR8 0SN
Universal T-Track Clamping Kit​
The TrackMaster is an all-in-one table-top clamping solution for use with T-Track and Mitre Tracks. This adaptable clamp turns the Milescraft 3" BenchClamp into a universal clamp for use on T-Tracks of different sizes. The kit includes T-bolts for attaching the clamp to 1/4", 13mm, 23mm, 30mm, or 35mm T-tracks.
The TrackMaster can be used with AUKTools T-Track and Mitre Track, INCRA T-Track and Mitre Channel, JessEm Router Table Tracks, router fences, pillar drill tables, table saw slots, and more. In addition, the TrackMaster Clamping Kit is compatible with any existing bench clamp that mounts to the bench using a 5/16"-19 fastener.
ONLY £31.46
Normally £34.96
Ends at midnight on 4th December. Discount automatically applied at the checkout.
Non-marring
The non-marring base shoe prevents scratching and damage to your work table surface.
Heavy-duty
The solid heavy-duty steel base helps spread clamping pressure evenly across your tabletop, reducing track tear-out.
With 10% OFF you can never have too many...
HURRY, Black Friday ends at midnight 4th of December. Discount automatically applied at the checkout.
Milescraft Track Clamps
Normally £21.95​
£19.76
AUKTools Precision Clamping Squares
Normally £34.96​
£31.46
FastCap The Jack of all Trades
Normally £59.95​
£53.96
Micro Jig MATCHFIT Dovetail Clamp AP
Normally £38.38​
£34.54
Jorgensen Adjustable Handscrew Clamp 8"
Normally £26.95​
£24.26
Jorgensen Medium-Duty Steel Bar Clamp 12"
Normally £19.33​
£17.40
