How best to cut prewar tapered, laminated, plane iron without losing temper
pgrbff
29 Oct 2020
Langhe, Piemonte
I'm thinking about building a shooting plane with a skew blade. How best to cut the blade without it overheating?
I thought carefully score with angle grinder and snap maybe?
Just to check - you are cutting the edge to an angle to turn a regular blade into a skew?
You can get diamond blades for cutting metal in an angle grinder- they work well, less likely to fracture than a fibre disk and cut quite cool. That with improvised flood coolant from a hose pipe should keep it under the temper temperature.
Otherwise a linisher and regular dunks
