Allen key
antifoul2020
5 Aug 2021
Scotland
Where could I purchase the proper tool for changing the blades on the Hegnar multi cut 2
Or do I just use a normal allen key also a new air line one that you can twist about
I'm sure Hegner UK would be happy to sell you the spares if you email or give them a ring.
I have a Multicut 1vs nd would just use a standard Allen key if I lost mine, or buy a T handle Allen key off ebay. I think I've seen flexible air hose on there as well.
OOPS just realised an Allen key won't fit :oops:
Would something like this suit for air line
Spray Nozzle Mist Coolant Lubrication Spray System Tube Valve for 8mm Air Pipe CNC Lathe Milling Machines https://amzn.eu/d/jfaFuII
ChgImposs 3/8" Thread Flexible Water Oil Coolant Pipe Hose, Round Nozzle Adjustable Plastic Cooling Tube with Switch for CNC Machine/Milling / Lathe/Hydraulic Machinery/Water Cooling System https://amzn.eu/d/70gd1NF
