Zebrawood vessels
Mark Placek
5 May 2009
Niagara Falls, USA
These two bowls are the continuation of my "Lostwood" series.
This technique allows me to make a larger turning using less material.
The left bowl measures: 12" x 17" x 3.5", the right: 12" x 18" x 3.25".
The finish is pre-cat lacquer. There is a third bowl in this series.
I donated it to Make-a-Wish Foundation, (this charity grants wishes of terminally sick children).
Your comments are always welcome.
Whilst I like these bowls and the design of them, the segmented zebra wood does thngs to my eyes. A bit like an optical illusion :lol:
Having seen some of the others you have done I much prefer them in a plainer wood as the design and styling is seen much better IMHO.
Having said that I'd love to be able to do these :cry:
Just had a look at the bowls in your gallery Mark, very, very nice. Although I do see what Pete means with the figuring of the Zebrawood bowls, does something to your perception.
Would I be correct in saying that all these bowls are laminated? Nice technique.
Very striking pieces Mark :shock:
No doubt the wood will darken as it ages so won't be as bad on the old eyes :shock:
I like em a lot.I like the laminations,Something different. :D
Mark, just been to your web site.Fabulous workmanship really love it. Very nice gesture towards the childrens charity as well,very thoughtful.I wish you well. REgards Boysie.
Breathtaking Mark, they are absolutely gorgeous 8) I love the effect of the figuring with the laminations.
I'm drawn very much to the one on the left out of the pair, I think the proportions,the dark and light 'ends' and the more striking broken pattern of the layers of wood make it really stand out 8).
They are very impressive indeed.
JT
Thank you for your comments.
These bowls are laminated using the "Bowl from a board" technique.
I use sacrificial wood in the center; after coming off the lathe, it's cut out.
This Zebrawood was left over from a conference table I made in 2002,
I recently found it in my shop stashed away in a cabinet.
The nice thing about using "BFAB" technique it use a lot less material.
Cheers, Mark
Interesting work Mark. IS the BFAB process documented anywhere?
Here's a tutorial showing the basic method for "Bowl from a board":
http://forum.canadianwoodworking.com/showthread.php?t=18252
I'm a member of this forum, It's one of my favorites.
I have expanded upon these instructions a lot in the past 5 years.
Turning square and rectangular bowls is my own variation, and also cutting the bowl after it's turned is something I have developed.
No other artist is making bowls in this manner.
I hope this explains the process to your satisfaction.
Mark :)
