xy mosian
For an up and coming project I need to be able to make lapped dovetails for drawers. I have never made a great number of these and as I cannot remember when I last made any I thought I should practise.
Practicing would also give me the opportunity of trying to overcome snags before the 'heat' of battle. Here is my first lapped dovetail joint.
Not too bad I think.
Right so:- My recently sharpened Spear & Jackson brass backed saw worked very well, no problem there. Holding the sliding bevel to mark the timber was fiddly, so I made a small dovetail template. While I was at it I added a 'square' template, always going to need that. The template is in Box and brazilian Rosewood (that has been in my scrap bin 30 years) and measures about 60mm overall. I really enjoyed making that.
The one area I think could cause problems, and the one I would like your advice on is marking out. I marked and cut the tails first, then I marked the pins from the tails. Now the problem area, I think, is going to be holding the tails in the correct position while scribing the pins. Do any of you have a favorite method of doing this? Do you have a method you think is foolproof?
I don't mind making the odd jig but I rather it was speedy in use.
xy
xy
