woodbloke
Further to our recent excellent MiniBash earlier in the month, Paul on the day went to try his Record No.4 where I had soft soldered the extension to the Clifton 'Y' lever and you'll never guess.......it wasn't strong enough and the whole thing disintegrated. So here's the way I've done it now. After the tops have been thoroughly cleaned a 2.3mm hole was hand drilled down the centre. I found that one of the main difficulties with these little beasties is holding the blo@dy things but if they straddle a large bolt then holding them in the vice very tightly is easy:
A piece of 3mm gauge plate is cut a fraction bigger than the top is then drilled with a corresponding drill and the whole lot is joined together by using industrial strength super glue and a piece of 2.3mm sprung steel, which will resist bending to a large extent:
Once cleaned up the 'y' lever looks like this:
and when fitted into the plane, it does now work without the top shearing off:
.....oops, how'd that JK woodie get into the shot.....getting as bad as Philly
....nearly :wink: :lol: - Rob
