gasman
I was commissioned to make this by a friend
His uncle had a DFC and bar from Bomber Command and he got hold of the medals, logbook, photos etc etc and wanted a presentation box to put them all in.
It is 3/4" thick English walnut heartwood, dovetailed all round, with a fielded panel for the lid under which is mounted the King's certificate (with a 2mm perspex cover). The lid was parted from the base using a Proxxon table saw with a 1mm kerf blade - couldn't be any more then that or the dovetails would have looked wrong.
There is a drawer which contains the photos. The front piece was cut up then reassembled so that the drawer is almost indistinguishable and the grain flows through it.
The medals and boxes are all in 5-10mm deep depressions taken out using a router - then I used flocking from Turner's Retreat for the first time - very impressed with it.
Sorry meant to do a WIP but never got round to it
The hinges are from Ian Hawthorne - very neat!
Finish is 4 coats of Danish oil then 2 coats Briwax
Mark
Mark
