twodoctors
Hi all.
Still very new to scrolling but getting the hang of it (I think).
I'm cutting some puzzle from a pattern of found on the net. Doing it with 20mm pine using a Clarke basic model (same as Ax Hobby) and pegas #5 reverse skip tooth blade. I'm finding myself pushing to wood quite hard to get things moving. Still moving it very slowly but I think (reads know) I'm bending the blade a fair bit. Some of the cuts ended up not perpendicular.
The blade is new... Used it to cut some ply and pine, and briefly oak and Beech. Machine is not a Henger. I think the tension is high enough... I'm fairly new to this but am quite gentle with the machine. Should I be using a bigger blade or different blade? It doesn't cut unless I out the wood onto the blade.
Tips welcomed.
Adrian
Tips welcomed.
Adrian
