Worried about the damp
Squarecoffee
New member
17 Feb 2014
Exeter
Hello this is my first forum post my issue is is that I have an open drain in my workshop (4mx2m) yes pretty small :( I'm worried about rust on tools , for example I would like to buy some bench tools but would be worried about rusting , I have thought about boxing it off any help . I don't have that much money to spend as I'm only 15 . The roof is also glass and one will is dampish .
So my question is can someone please help me find a way to make warm and safe for tools :D
Get hold of an old kitchen cabinet unit/set of draws/chest of draws etc. or make a tool storage cabinet/chest.
Put a small low power heater in the base such as a vivarium mat or low wattage bulb.
All you need to do is keep metal tools a couple of degrees above the shed temperature and any moisture will not condense out on the tools whilst in storage.
Keeping the workshop aerated if possible should also help.
I use a single garage for tool storage and some hand tools are stored in open cabinets, however luckily I don't seem to suffer with rust or damp problems.
The garage is aerated due to an air brick situated up about 2 mtrs high in the rear wall.
Store the tools in the house under your bed. Or buy some old already rusty tools and you won't have to worry.
That is pretty much what I was thinking. What are you actually storing in the workshop ?
Mainly files a drill press , looking to get into knife making ! Wondering mainly about the drill press , could I apply mineral oil every time I use it or make a box cover for it ?
There is a product called Boeshield T9, a little expensive but then so are tools if you have to keep replacing them, it is available from Rutlands and one application will last for months so a can if used carefully should last a few years.
If your drain is not too big could you not vent it up through the roof? maybe a bit intrusive if it is in the centre of your workshop but as Nolegs said the best thing is go to the builders merchants and get a drain lid. If there is not one small enough then get the smallest available with a frame and concrete the frame down around the open drain and sit the lid into it.
Andy
