Racers
- Joined
- 22 Apr 2005
- Messages
- 9,172
- Reaction score
- 136
Hi Chaps
While searching for some tap washers I found this Workzone plane.
Workzone scrub plane conversion by Racers, on Flickr
As you can see it was reduced, so I bought intending to make a scrub plane out of it.
So after drawing a 150mm radius on the blade I ground it back to the line, then sharpened it.
I widened the mouth with a coping saw.
And tested it on some Iroko.
I did smooth the corner of the block at the back where your thumb goes to make it handle a bit better, but it took me only about 20 minutes to do the whole conversion.
