Hi all
My first post here, I am looking for a advice on a few things if I may pick your collective brains.
I am fitting a new kitchen/utility and my next job is to fit 40mm oak worktops supplied by diy-kitchens. I haven't unwrapped them yet, but I assume they are finished to approx 150grit as their online advice says to oil with no mention of sanding first?
So first question is would you sand the entire top first before oiling/sealing?
I will have 3off butt joints to make with 3off dog bone clamps per joint. So the second question, is there a recommendation on a decent jig to cut the dog bones? I don't need anything special as won't be doing any mitre joints.
Onto the third question, how is best to join the butt joint? I have read of 2 ways so far that stand out.
1. Silicone along the joint and pull it up tight with dog bone clamps until it spews out.
2. Biscuit joint (I have bought a 1/2" router for this kitchen and will get a biscuit bit if needed) and wood glue the joint together.
Next question, if I require additional sanding of the tops prior to oiling, which orbital sander would you recommend? I see various mentions of the Metabo 450, there appear to be various versions of this so am unsure if they are all similar. Or is there a cheaper alternative that can do a decent job?
Last question hopefully, what would you recommend for sealing the worktops?
Research has me finding 2 general opinions.
First is to coat with danish oil, 4 to 6 coats and very frequently topping it up as required.
The second appears to be wax oil, such as Osmo Top oil. I have bought Fiddes Wax oil for when I sand my pine floors (another job on my growing to do list), is that similar to the Osmo?
I am aware this is a heavy first post. But any advice for any of these questions would be greatly appreciated. Especially if we have any kitchen maker/fitters in the forum.
Thanks all
Mike
Thanks all
Mike
