I am building a workshop (4m x 7.5m internal size) on top of this:
It is framed in 150mm which I plan to insulate with fiberglass or rockwool. I don't plan to heat it continuously, only when I am doing work that requires it.
What to put on the walls? My first thought would be drywall, but in an unheated structure I am worried it would attract damp. I also thought plywood might be an option. Either way, I am not sure if vapor barrier is a good idea, as would be required if it were heated and warm inside.
Any suggestions?
Any suggestions?
