Hello forum,
Bad planning has led to a problem with the roof insulation / ceiling.
I had planned on putting insulation between the roof rafters then a vapour barrier over bottom of rafters and then shuttering ply for the ceiling.
However, the beams which are fixed across the rafters cannot be removed at this stage, which means that the vapour barrier would have to go up in three pieces between the two beams.
Is it still worth putting up in three pieces of vapour barrier up, or can I go ahead put the insulation (rockwool) in and then ply ceiling?
Roof structure above is slates / battens / counterbattens / vapour barrier / wbp ply / rafters.
Sorry if I’ve used the wrong terms , total novice.
Any info much appreciated , cheers.[/img]
