Sawdust
I have spent the last few evening rearranging my workshop. The two things I wanted to achieve were more space around the tablesaw and a an area where I can assemble large items.
I have moved the tablesaw into the the middle of the shop and placed it such that there is enough space around it to cut a full sheet in half either along its length or across its width. At the moment there is a roller stand behind it for support but I plan to make a good sized outfeed table which will also double up as an assembly table.
I intend to make a stand with wheels for the planer so that if I need to work on very wide pieces on the saw, I can just push it out of the way.
The bench area is to the left (nice and close to the stove). The bucket underneath is full of clamps.
To the right is the temporary router table. I have recently obtained a Triton which I have put into my old table until I have time to build a new one.
On the back wall is the radial arm saw which has 9 feet of clear space either side of it for cutting long planks.
In the pictures there doesn't appear to be much space between the machine but in reality there is easily toom to move around them and they have all been placed so that long boards will go through them without moving anything.
Finally, the large area for assembly with my little bandsaw in the background.
Sheet storage is to the right of this area and there is easily enough room to put a sheet on the floor for initial cutting with a circular saw. It is also handy for the garage door so when I have timber delivered the truck can pull up to the door.
Mike
Mike
