... there is no demand for daylight tubes, because no sane lighting designer will use them except for very limited special purposes. They sound like a good thing - daylight must be good - but that's an enticing fallacy.
Honestly, what you like about them will be the high CRI compared to old fashioned single phosphor tubes, not the colour temp which is way too cold.
HF fittings good, triphosphor tubes good, but colour temp needs to be matched to your lux levels. The brain is a finely tuned thing and adjusts its perception of colour to match light levels - it is adapted to brighter, colder, bluer (higher colour temperature) light at midday, and dimmer, warmer, yellower (lower colour temperature) light at either end of the day. If you have a dimmer high colour temperature light, the brain will see it (and the stuff it is illuminating) as colder and bluer than it would do under the colour temperature it is evolved to expect to receive from the sun at the level of illumination you are achieving
http://en.wikipedia.org/wiki/Kruithof_curve
Remember that feeling you get from going from somewhere shaded into mid-day sun in the summer, when your eyes have to squint while getting used to the light levels? That's the sort of level of luminance you have to achieve to make a daylight tube the right choice of colour temperature. In the real world, that isn't going to happen.
High frequency electronic switchgear is important (and you need to look, old fashioned stuff is still about), and so is a good quality tri-phosphor tube as they have a much better CRI and give a much more pleasant light than the fluo lights of old. Definitely go for a 3000k-3500k colour temperature.
