Yojevol
Clocking on
This is a 12" jig together with a small range of cutters which will cover most requirements for furniture making. I've used it successfully on a number of projects involving multiple drawers.
It's an imperial measure unit but that needn't worry you if you're a metric man. The jig is infinitely variable. in terms of spacing. material thickness and depth of cut.
£150 if collected from GL19 or + P&P if required
Brian
Brian
