• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Withdrawn Workshop Downsizing - Apollo HVLP Spray System
Yojevol
Clocking on
29 Jan 2017
Wotton-under-Edge, Glos
Apollo Pro-Spray 1500 - 3s with Walcom gun/reservoir system.
Has had little use but a seal needs renewing on the gun.
£250
Collect from GL19
If you're interested contact me quickly otherwise it's going off to auction next week
Brian
Can I ask- How did you get on having the pot on it ?
I've the Fuji Spray Mini-Mite 3 Platinum Turbine Unit & G-Xpc Gravity Spray Gun, but the gun doesnt really hold a lot, and I've some jobs in mind that will require greater capacity, but I wasnt aware you could add a pot to the smaller fuji compressor units.
I know the one i have is a bit more powerful than the Apollo, so if yours works ,then mine should also. But I dont want to outlay for a pot only to find its not got the oomph.
Any advice/review/thoughts to offer on the system you've been using ?
Amongst other jobs,I actually want to do some exterior walls with masonry paint. I can use a standard gun, with correct needle/nozzle,just interested in how the pot is compatible
Coupled up to something like this
https://www.machinemart.co.uk/p/cla...VKzwGAB2LcgPBEAQYAiABEgIQBfD_BwE&gclsrc=aw.ds
To be honest I only used it 3 or 4 times, I should never have bought it. However when when I did use it I had no trouble in achieving acceptable results. All I can say is that the gun/pot combo was fine but I can't give any further advice.
Brian
