IanB
Hi all, I wonder if anyone can advise on calculating my lathe speed?
I have a lathe with a 3 phase motor running off a domestic power supply. It has a control knob to regulate the speed, but only with numbers 1 to 10. I would like to be able to work out what speed the lathe is running at on any particular setting of the control knob.
Below is a photo of the motor plate, most of which I don't understand but it does include "1400/min", which I assume is the rpm of the motor at full power. From this I assume I can calculate the maximum rpm of the lathe spindle by measuring the circumference of the two wheels on the belt drive and doing the right sum.
Does that sound right? And if so, my main question is, can I assume that the control knob increases the speed on a linear scale of 0 to 10? Eg at setting 4, will the speed be 4/10 of the maximum spindle speed?
Any advice appreciated!
Thanks,
Ian
Thanks,
Ian
