Charley
Some of you may remember that I mentioned we have an old woodstore which the last owners didn't clear for us?
Well it had to be cleared and the door opening made bigger so we could get the ride on mower in there (an old rusty one that you spend more time fixing than cutting the grass). The whole job took just over three days. Taking out the old lintel took nearly 3 hours as it wouldn't budge even though the only thing supporting it was cement. Anyway we found everything in there including metal sheeting, loft boards, mdf, hardboard, chipboard, bricks, breeze blocks, air filters, plumbing fittings, copper, plastic and lead pipes, chimney liner, plaster board, doors - basically you name it we had it in there. Unfortunately I didn't find any decent sizes of mahogany other hardwood as I was hoping, but we have got a large amount of what looks like very old pine.
I took one piece into the workshop and as I haven't got a metal detector I haven't risked putting it through the thicknesser yet but I have planed a little bit off one end and there are signs of woodworm. Now how can I tell if it's active? And if it is, what's the best way to treat it that won't stain the wood too much? Should I plane it up then treat it? I've never dealt with woodworm before so I need all advice I can get
