tool-me-up
Hi all Im putting together various kits for various jobs for example a plumbing kit would include spanners, pipe wrenches, water pump wrenches, blow torch solder pipe cutter, pipe cleaner and a couple of adjustable's etc
I'm just after some advice on the wood work kits im starting to make lists and getting ready to sort out the accounting and prices etc once I know what will be in the kit.
so any thoughts and opinions on them? Is there even a market for these "kits" or collection of tools - its definitely not something thats offered a lot but that doesnt mean theres no interest.
Id just like some opinions of what I propose to include in each kit - too much - too little not needed etc.
Ill post each one separate to keep things simpler.
Fist one is introduction to woodworking kit its aim is to give the end user most of the tools needed for general woodwork projects without having to go and "find" each tool.
I know requirements vary from project to project so ive tried to generalize this a bit.
Round Point Bradawl
Carbon steel round blade with tapered end to reduce timber splitting. Beechwood handle and brass ferrule. For hard and soft woods.
Wood Chisels Set 5pce
Forged, 1-piece, bevel-edged chisels. Hardened and tempered, sharpened and honed, ready to use. Comfortable polypropylene handles. Sizes 6, 13, 19, 25 and 32mm. Supplied with blade guards.
Tri-Cut Tenon Saw
Triple-ground teeth for fast cutting through hard, soft, and man-made wood. Cuts on forward and reverse strokes. Comfortable soft-grip handle and low-friction blade coating.
Mitre Box
Hi-Vis polypropylene mitre box for accurate cutting of mitres and butt joints.
Tri-Cut Saw
Triple-ground teeth for fast cutting through hard, soft and man-made wood. Cuts on forward and reverse strokes. Comfortable soft-grip handle and low-friction blade coating.
Euro F-Clamp
Cast-iron jaws with soft plastic covers to prevent surface damage. 300 x 120mm
Wooden Mallet
Durable hardwood mallet. 115mm face.
Adjustable Bevel
Polished hardwood stock with solid brass end cap and adjusting wing nut. Blued steel blade. 190mm
Carpenters Square
Hardwood stocks and blued steel blades. Heavy gauge brass faces for accuracy, and 3 rivet fixings for strength. 150mm
Nail Punch Set 3pce
Precision milled and fully hardened carbon steel. Includes sizes 1/32", 2/32" and 3/32". Square, colour-coded polypropylene coverings provides extra grip.
Hand Plane No. 4
Rosewood handle secured with 2 brass screws. Milled sides, brass adjusting screw and heavy duty 2mm blade. Simple, rapid adjustment mechanism with easy blade removal for sharpening and honing. Fluted base reduces friction on resinous timbers. Blade width 50mm.
Portable Workbench
Lightweight, strong, portable workbench ideal for site work. Folds easily for storage and transportation. Includes 2 x worktops. Worktop size 560 x 110mm. Max load 100kg. Requires assembly.
Hi-Vis Contour Tape
Comfortable contoured shape. Secure triple-riveted wraparound tips. Clear metric and imperial graduations with joist centre marks every 16". Includes belt clip and hand strap.
Carpenters Pencils & Sharpener Set 13pce
Soft-lead oval-section carpenters pencils for marking timber, brick, stone and other building materials. Draws thick or thin lines on both rough and smooth surfaces. Oval-shaped length means pencils do not roll away when placed on inclined surfaces. Includes 12 pencils and sharpener.
Lip & Spur Drill Bit Set 5pce
Precision-ground, high carbon steel bits. Sizes: 4, 5, 6, 8 and 10mm. Pre-cutting blades for a cleaner cut.
Cork Sanding Block
For use with abrasive paper for sanding by hand.
Round Point Bradawl
Tri-Cut Tenon Saw
Mitre Box
Tri-Cut Saw
Euro F-Clamp
Wooden Mallet
Adjustable Bevel
Carpenters Square
Nail Punch Set 3pce
Hand Plane No. 4
Portable Workbench
Hi-Vis Contour Tape
Cork Sanding Block
