thecoder
having just watched the promo video for the woodrat I wondered if anyone has one and if they can give a spot of end user feedback please. I note that if not satisfied they will accept returns anyone had to do this ?
JonnyD":mtq5efu3 said:I haven't used mine for about 10 years but it was quite capable . Might dust it off and give it a go again.
Jon
Harbo":h1k8zdy9 said:Had mine about 8yrs - great bit of kit once you get your head round it.
This website will give you a vast amount of info:
http://www.aldel.co.uk/
Rod
thecoder":mckm9jyj said:JonnyD":mckm9jyj said:I haven't used mine for about 10 years but it was quite capable . Might dust it off and give it a go again.
Jon
You might want to sell it Jonny after all that time :wink:
marcros":32c0olvs said:I have had mine for a few months. i am yet to cut dovetails on it, but if it broke, i would replace i with exactly the same- brand new if necessary. it really is that useful in my opinion. In fact, i could do with a router to leave permanently on it.
I need to build a router table at some point, but it is always on the back burner because the woodrat does 90% of what i would need a table for. the only real limitations i have found is running small mouldings and holding flat pieces. the latter, certainly can be done with a jig which i really should make. the windey handle power feed is worth the price in itself- set the work, set the router and wind the handle with your hands safely out of the way.
you are only in ponte- i am in north leeds (kirkstall). come and have a go if you want...
Giff":2fx6twwa said:I bought one second hand earlier this year and as others have said it isn't the easiest to use. I still use a router table a lot more.....having said that there are some things that it is brilliant at, sliding dovetails, slots. Adel's site is really good as well, and there are various jigs to make, which are necessary for some things. I bought mine on ebay with a router, and do think it would be a bit of a faf if you had to mount the router each time. Geoff
marcros":3czkr32e said:it isnt so much jigs for different joints- more like jigs for different work holding, for example a horizontal table so that you can clamp things to it.
it isnt a huge faf mounting and demounting the router- a couple of screws on mine. i can see why you would buy a second router but it isnt essential.
thecoder":3g76pjs2 said:marcros":3g76pjs2 said:it isnt so much jigs for different joints- more like jigs for different work holding, for example a horizontal table so that you can clamp things to it.
Ah got it that makes sense. do you have the plunge bar for yours marcros ?
