Woodrat mods
It sounds pretty ingenious but I look forward to seeing the photos as I can't quite work out how it will work in practice - getting dim in my old age I guess!
Here are the pictures of the prototype.
This is the setup for normal use, the router sildes north/south at 90 deg to the woodrat face. The 15mm MDF bottom plate reduces the max depth of cut so I will replace this with 6mm aluminium now I know it works. The 6mm MDF plate pivots on the lower plate and is locked by the screw in the curved slot at the right. The bottom plate can be adjusted to change the pivot points position in relation to the woodrat face. The ali extrusion on the right is fixed at 90deg to the woodrat face so when adjusting the bottom plate north/south it can be pushed against this to make sure everything stays square.
Here the router is swung to the right for dovetail pin cutting. The orange pegs are set for a 1:7 pin slope. When I remake it in aluminium will add better made stops for different pin slopes.
A close up of the pivot locking screw (this will be replaced with a knob that can be tightened by hand as will the cap screws for the main plate adjustment.
The router is slid forward here to show the pivot point.
Everything removed except the bottom plate to show the pivot point.
A couple of pictures of a completed joint.
I use Aldels method of cutting the tails then marking out the pins from these and then cut to the lines on the 'rat so dont really need the north south adjustment on the bottom plate.
The big advantage is that when changing from cutting the tails to the pins you just have to loosen the locking screw and then you can pivot the router to cut the pins. No removing the guide rails and no messing about with the button.
Very nice indeed, now another thing for me to make, all the renovations and the list of furniture to be made may be delayed again!!!!
Hi Johnboy,
Impressive stuff. I was a little confused by your technical drawings but the photos now make it so much clearer. I am wondering about the available depth of cut as you have three layers to pass through before reaching the work. I guess an alloy plate will improve things there.
Isn't it great when an idea actually works?!
Regards, Aldel
Thats very interesting ........ once you remade it with the alloy / aluminum plate could you let use know how it works out as I for one will be very interested .........
thanks
Ian
