Wooden plough plane
ac445ab
7 Jul 2007
Naples-Italy
Hi all, :D
I bought this plane on ebay.
The maker was W. Parkes. After some repairs (new wedge and lateral keys) and set up, it is waiting for cutting grooves again.
I have some questions:
What is the correct grinding angle of the iron?
Is a microbevel a right option?
I copied the wedge from another plane I had, but I am not sure if its lenght (see pic) is right or I need a longer one.
Someone knows its approximate age?
Thank you and excuse me for so much questions
Ciao,
Giuliano :D
Hi Giuliano,
I think I have the same plane (stored away in the loft).
Can you post a picture of the Irons you got with it?
I have a set of about 12 (I think) with mine. They seem virtually unused so I could check the angle for you
One day, I intend to get mine out and clean it up and learn :roll: how to use it.
lurker":1v0qz869 said:
Hi Giuliano,
Unfortunately the plane came whit one iron. But I bought apart a set of five blades that fit the plane. :wink:
Ace Karner":228is7zz said:
Mine are 35 degrees with no micro bevel, seem to work well.
ace
Hi Ace, :D
thank you for this indication. I will try that angle without microbevel.
I measured the bevel of other old irons I have. Angles are between 25 and 30 degrees, so I assume 25-35° could be the right range.
Are there other users of these planes?
Ciao,
Giuliano :D
Absolutely--different maker, but yep.
As well as metal plows. Love them all--including the graciously supplied 044 I know possess...
I've used my wooden plow since I got it (to replace a Stanley #55 I had) for bigger grooves and wasting hollow areas and creating the fillets of moldings prior to using a set of hollows and rounds. I'm still getting use to it. Quite a bit different than using my #55, but it's a solid user.
Enjoy yours--it looks like it'll work great now that you have the wedges made.
Take care, Mike
