Bluekingfisher
I recently bought a small wooden plane. I must say I have very limited kinowledge of them so I have two questions which someone may be able to assist with hopefully please.
The plane is good condition, no damage as such, crisp corners, no obvious signs of wear, although there is a little pitting on the back side of the iron at the top end, the business end is perfect.
http://www.ebay.co.uk/itm/171979096270
I assumed these small planes were the equivalent of the #4 Bailey style of plane? The obvious difference to me in that regard is the limitation of iron advancement. The front of the mouth, which is crips and straight leads the cutting edge by about 4 - 5mm. A large gap by any account.
I haven't used the plane as yet as it only arrived last night but how do such planes cater for smoothing (assuming this is what they were for) The comparatively wide space between mouth and iron is not surely condusive to fine shavings or reducing tearout.
The other question is, what is the approx vintage of the plane? any ideas?
It is a Mathieson plane with the makers stamp on the front and a small transfer on the toe with the makers name on it. It has a 2" iron and cap iron. the cap is stamped "warranted" the blade is a Sorby ( I think) the figues' 2in' are stamped on the heel.
Edit - The blade is of the same maker.
Sorry one more question - when placed on a flat surface (kitchen worktop) it rocks slightly at the toe, although flat it seems the toe is slightly higher than the sole behind the mouth - does this need rectifying??
David
David
