Kicked Back
I have a T-slot cutter and want to put a grid-like pattern of t-slots on a piece of MDF for jig making reasons. For the shorter axis I'm using a mitre gauge rather than the fence to 'crosscut' the channels into the MDF. However, the rotational force of the cutter causes the MDF to get pulled along the mitre gauge, giving a diagonal cut...
When holding the piece tightly against the mitre gauge, this was huge (I could see it moving, and gave like a 70 degree cut instead of 90. So I clamped the MDF to the mitre gauge fence and this was far closer to 90 degrees, but there was still slippage. Measuring with calipers it still drifted around 2mm out of square, and putting a straight edge along the channel you can see it looks a bit wonky too.
I've never used a mitre gauge on a router table before and this caught me totally off-guard. Any better ways to 'crosscut' stuff on a router table?
