Heath Robinson
Hello all.
I'd like a bit of advice and any thoughts on the design of windows, and which wood to use.
I'm building 5 windows to fit in the box body of a friend's 40's army truck. The interior of the box is beautiful, all wide boards of elm and yew.
The window apertures are all in the region of 615mm x 535mm, and the walls are about 65mm thick (there's about 7mm variance as standard, due to precision American manufacturing techniques). They all need to open, and I'll be using double glazed units for the glass. I'm thinking that a combination of plugged screws and tiger seal should hold the frames into the metal frame of the truck.
Any thoughts/hints/ideas on wood/jointing/sealing would be greatly appreciated, as I've never done anything like this before.
Thanks,
Jake
Thanks,
Jake
