wing nuts
Maynot be appropriate but I make this sort for my jigs etc.
Ian
    2.7 MB
    2.9 MB
Tried looking at drum (the musical instrument) hardware? M8 wing nuts and bolts are quite common.
Another place to look is marine chandlers as there are a few options in stainless that tend to be bigger than a standard wing nut. eBay direct from China is an economic source.
I like the shape and design of the wing nuts off old bicycle wheels, so buy them when I see them. It is easy enough to convert the thread to someting more modern.
As above, 'butterfly nut' is an alternative search term.
I made a few thumbscrews/wing nuts for some marking gauges the other day, these are the rejects.
Surprisingly strong, at least I can't break them by hand, would need some serious torque to split/break them.
Figured out tapping a thread didn't work, nigh on impossible to get the tap to run true, so the 10mm (Walnut) one's I just pre-drilled @ 3/8" (9.525mm) then chucked up the 10mm threaded rod in a cordless drill, bit of CA on the end, then inserted, lovely snug fit.
I made a few thumbscrews...
I am wondering if you have included an incorrect photograph by mistake.
This thread is entitled "wing nuts". The text below the thread title says "extra large/long 8mm wing nuts". Later on, the OP says "it needs to up and down a thread".
I am failing to see how the items pictured meet those criteria. To my simple mind, a nut has a female thread, not a male thread. Please explain. Thanks.
I made a few thumbscrews for some marking gauges the other day, these are the rejects.
Those look so much better than my quick lashups made from a coach bolt and ply.
Ian
Better?
Which I think you'll agree, isn't particularly descriptive as to the usage.
Either way, my post and the pic were merely offering a suggestion, or possible adaptation thereof, if it doesn't meet the OP's criteria, then fair enough.
A wing nut - "it needs to up and down a thread". (as opposed to to onto a stud.)
How else should I have put it? :LOL:
(your post was fine, though, a little off tack but ideas are always welcome.)
Did you get fixed up as I have one 70mm across the wings, same as thingybob's image above.
Edit: your welcome to it for the postage.
