softtop
Right, here we go for my first project, with pictures. Actually, having started this I have to say I’m very impressed that you all manage to do the pictures as you go because I kept forgetting!
My previous carpentry experience has been fairly rough and ready, and mostly involved MDF so go easy…
We have a set of 5 windows in half an octagon at the front of the house (two small ones on either side, 3 large in the middle), which originally had vertical sliding shutters but these are missing, and there has been a certain amount of neglect, rot etc.:
Underneath each window should be a shutter box but most have rotted out, along with some of the slides for the shutters:
Here is one original one, with sash pockets removed on either side:
And here are my supplies for the project. Lots of Dougie Fir (as recommended for replacement of old pine on Georgian buildings):
First off I replace the rotten slides where necessary, and add in some Celotex insulation as it gets very cold in here:
Then I have decided to line the boxes with damp-proof membrane as the shutters sit well down below floor level:
Replacement Boxes for below the windows
First I cut out the lengths of timber roughly with the SCMS:
Then I cut them down their lengths to roughly the right width (I don’t have a TS):
Next I plane two faces flat:
Then it’s lots of thicknessing:
…and lots of chippings. Luckily I can use these in my wood-fired boiler:
Now to join the various bits together, out with a new toy (well second hand but still b*st*rd expensive!):
Clamp up the pieces (didn’t have wide enough timber for the bottom sections of the boxes):
Then I need to rout out a channel for the recessed panel to sit in:
I’ve got some 6mm birch ply for the panels:
Dry fit (this is one of the small panels):
…and then glue up:
Here is one of the large ones, all glued. Just needs trimming to the right height. I have some mouldings I reckon I can reuse round the recess:
Shutters to come soon…
Thanks for looking.
…and then glue up:
Thanks for looking.
