Wide kerf FTG table saw blade.
DaveG
7 Oct 2020
Wales
Hi
Can some advise me where to acquire a wide kerf FTG tablesaw
blade please.
you could look at a grooving blade. I got mine from Biven, it was a CMT I think. The size is 150mm, but you are likely never looking to cut deep groves with it so that was fine.
As above, I bought the CMT grooving blade direct CMT, about £40 for a 6mm kerf. Perfect for making the corner joints for drawers in my 50 drawer setup.
Depends what kerf you might need and the diameter.
150 mm are available in 3.5/4.0/5.0/6.0
180 mm are available in 4.0/5.0/6.0
200 mm are available in 4.0/5.0
Hi
Hi Doug
I am currently using a 250mm blade
I am currently using a 250mm blade with a 30mm arbor and 3mm kerf. I’d like to go up to a 6mm kerf
Just keep in mind that the FTG blades are pretty much only good for work where your working with the grain (IE, ripping work, finger joints), using them for cross-grain trenching work is like trying to cut down a tree with the flat face of a spade.
