katellwood":2wz559pj said:I'm on my second combi and for a one man band/hobbiest they are excellent
My first was a Lurem C210B, cast alloy saw/spindle and cast iron planer thicknesser tables. I bought it in 1987 for £750 and sold it in 2005 for £900.
My second and a replacement for the Lurem is a Felder BF5 1986 vintage. all cast iron with three motors, an excellent machine. the 12" wide P/T is a distinct advantage and the tilting spindle moulder makes this machine much more versatile
Only waiting now for retirement when I plan to opt for a upgraded felder with a longer sliding table.
One other thing I have found with both my combi's is that the space needed to increase the sheet ripping facility is not wasted as it is the planer beds. on a standalone saw with a large rip capacity this space in my opinion is often wasted
heimlaga":1nryjump said:I have a Stenberg planer/thicknesser/spindle moulder/table saw combination. Manufactured in Stockholm in 1957. The spindle moulder and table saw were optional so some machines turn up without one or the other. Usually without spindle moulder.
I also think AB Naula OY in Jakobstad in Finland made a planer/thicknesser/saw combination in the early 50-ies.
Felder certainly made such a combination in the 70-ies or 80-ies sometimes.
However I prefere all four in one machine.....or if I had room enough for separates with the same capacity as the Stenberg that would be my choice. However a 610mm planer and a 610 mm thicknesser and a 400mm/5hp table saw with sliding table and a 3hp spindle moulder would take up quite a bit of space.
katellwood":16cpbqt5 said:katellwood":16cpbqt5 said:I'm on my second combi and for a one man band/hobbiest they are excellent
Nice to see this has been resurrected
For those that are interested my combi's so far
First my Lurem
Then my first felder
Then my current felder
For a small workshop I don't think you can fault them.
Most dedicated panel saws have the cast top then a sheet metal piece to the right of the blade, with a combi this is substituted by the planer tables (yes I appreciate with a single saw unit it can go up against a wall)
With regards to the spindle, very few stand alones have a sliding table of this length. I have found this exceptional for planing perfectly straight and square large pieces of timber for edging using a spindle block (much better than attempting to balance and hold tight to the fence when going over the surfacer) in addition with a tilting spindle bevels can be carried out with greater accuracy.
Finally, since getting my current felder with the sliding table and outrigger I have not used the RAS once
marcros":2yp8ionx said:katellwood":2yp8ionx said:katellwood":2yp8ionx said:I'm on my second combi and for a one man band/hobbiest they are excellent
First my Lurem
how does the 1st felder stack up against its newer replacement?
