Can someone help on this?
I bought a 4.8m length of 200mm x 45mm C24 softwood from my local timber merchants cut it into 3 and glued it together.
24 hours later I removed from clamps and give it a good sanding.
Then I fixed 2 2x1 inch support pieces 6 inch from the ends to the underside. I then applied 1 coat of danish oil to to the underside followed by 2 coats to the top surface.
5 days later I noticed that it had cupped I would say around 10mm over the 600mm span, lied flat surface facing up the ends are 10mm higher than the middle.
For 5 days it was leant vertical against the wall. The table top is only for a guy I work with for his garage so really no big deal but why did it cup?
Can different coats affect things?
