Blackdiamond2
So pretty much all bevel up planes, be they block, jack, smoother, jointer or any other are bedded at 12 degrees. I was wondering for what reason was that 12 deg bed angle chosen? I've read that the old Stanley no. 62, the father of all modern bevel up bench planes (I think), had a chipping issue on the rear of the mouth due to the casting being too thin, and the cast iron they were made from was inferior to the ductile iron most good planemakers use today. So I can understand why Stanley would not want to go lower than that 12deg, as it would have made the planes even more fragile.
Bu times have changed. That ductile iron means that planes are tougher, and potentially could go lower. I've been thinking that a 10 degree bedding would make a lot of sense, and that 12 just seems kinda arbitrary today.
Most people who use bevel up planes use a honing jig and microbevels to set the sharpening angles on their irons consistantly, and these jigs often only go in 5 degree increments. The Veritas has a couple in it's eccentric roller, but eclipse styles require you to do a bit of trigonometry yourself to get an accurate sharpening angle that isn't a multiple of 5, as do the Richard Kell guides and most others out there. 10 degrees would be far more convenient to use, as it's a multiple of 5 itself, so all of the other multiples of 5 including common, york and higher pitches would be way easier to grind, as you just add 10 to the sharpening angle. With 12 degrees, you end up having to settle for odd angles like 37, 42, 47 or 62 rather than the cleaner, more accessible 45, 50 or 55. Am I the only one who doesn't know how to set up my honing guide to 38 degrees? Why do people even sell 38 degree blades?
Anyway, the issue boils down to the numbers aren't neat and they're different, so it creates a bit of extra effort if you want to stay aligned with your bevel down compatriots. The bevel up angles with their special +2 degrees will still work just fine, it's just that it's inconsistant for no apparent reason in the modern day. A bit of simplification and streamlining to make things easier to understand isn't a bad thing.
Anyone know if there's a good reason that bevel up planes are bedded at 12 degrees? To be honest this isn't really even and issue and it seem like I'm the only one that cares about this, but I figured I'd ask anyway rather than stew in silence.
