Which ?
For pen turning only I think the second smaller lathe looks more suitable.
It has a higher top speed compared to the first, which gives a better finish when turning small diameter spindle work.
It also seems to have variable speed rather than just the four pulleys that the first one has, and depending on the nature of that variable speed feature this would be an advantage also compared to the first one.
Both have a 3/4" x 16 standard spindle thread for which it's easy to obtain accessories, but neither state the bore size on the spindle or the tailstock. I would expect this to be MT1 given the thread configuration in which case again you won't have any problems with accessories, but if they are some other size then that could be problematic.
Hope this helps !
Cheers, Paul :D
Hi Tiler
I have a SIP mini lathe... neat little job used mainly on demos 'cos of its portability. Only one small criticism, the cam lock on the tool rest isn't as positive as it might be!
Have you looked at the Axminister M330 (I have one of these too!)
http://www.axminster.co.uk/product.asp?pf_id=29953&name=m330&user_search=1&sfile=1&jump=0
it's more robust but doesn't have variable speed (I leave mine on max speed so it's no problem)
Or http://www.axminster.co.uk/product.asp?pf_id=21733&name=perform+lathe&user_search=1&sfile=1&jump=0
Do you have another lathe available? The reason I ask is that you don't need a dedicated pen lathe to turn pens... or any miniatures for that matter. (I once turned a 3mm dia apple on a VB36 :lol: )
Hi tiler,
i had the clarke version of the SIP 1-M starter lathe - and i grew to hate it, it ate belts like nobodys business, it wasn't rigid and the tail and headstock were solid (no morse taper), the build quality was poor aswell and the free tools are barely suitable for opening tins of paint
http://www.machinemart.co.uk/product.as ... 2129&g=116
Machinemart now do the scheppach lathe that's similar to the M330.
but on the positive side it was a great christmas present as it got me hooked...
jim
tiler99":19lzn6yl said:
Thanks i will look into all choices. I dont have a lathe of any kind at the moment.
In that case, think beyond pens :wink: if you get hooked on turning you'll want to try allsorts... remember, you can turn small things on a large lathe but small lathes have their own limitations... good luck!
Following on from oldsoke's point - with which I totally agree - if you have the space, why not consider a second hand larger lathe?
In the local FreeAds (in the south so maybe not of direct use to you) I recently saw a Union Jubilee with an electronic variable speed drive (normal 240V mains plug input) for just under £300. It was to be supplied with "toolrests, faceplate and two Nova scroll chucks, with 80 woodturning blanks all sizes."
To me that sounds like very good value compared to what you'd get new for that price. So long as the machine has been treated with care, there is relatively little to can go wrong. You may have to replace the drive belt on an older machine like that, but so long as the bearings are in good order (quiet, smooth) and all the moving parts have been lubricated & protected from rust etc., I think many of these older machines will be much more satisfactory than those new machines of the same price.
If you want to turn pens, as has already been mentioned, one specific thing to check is the speed range, you will ideally want to get up to 3000rpm or so to get a fine finish more readily. So long as you can get a suitable speed, and the spindle and tailstock tapers/thread are such that you can fit a pen arbor (and later, no doubt, other accessories), you can turn a pen on any large lathe. However, if you decide you want to turn a new 12"+ diameter fruit bowl, you're sure to find it much less stressful if you have a machine with the mass of plenty of cast iron to suppress the vibration.
Hope this is of help,
Neil (who's just wishing there was room in the shed to squeeze that Jubilee in alongside the Vicmarc)
Space is a big problem and that's a reason for wanting a small lathe. I found your info very informative though tigerturnings. Thank you
Wow, sounds a great deal Neil, the chucks and blanks alone are probably worth that price so the lathe is pretty much free :shock: :lol:
Cheers, Paul. :D
