bertterbo
I'm wanting to make an "articulated" arm type thing (although it will only rotate in one plane). As shown in the image below, the grey bars will be 3030 aluminium extrusion, and there will be an M8 bolt going through the 3 pieces as shown by the black line.
The grey pieces on either end should be able to rotate freely about the bolt, however, I'm trying to build it with as little play as possible. In my test, I just used penny washers between each connection, and then using a lock nut, I tightened it as accurately as I could so that there was zero play, but the pieces could still rotate. As you might imagine, I couldn't achieve that.
I appreciate that ideally, I would drill large holes in the grey pieces to take bearings, but I don't have the equipment to do that accurately. Just a bench drill press. So I then looked into thrust bearings, that could replace the penny washers and do a better job of zero play, but still allowing things to rotate. However, they're very expensive (£5 a piece) and have a very small outside diameter of around 16mm, half the width of the 3030 extrusion, so not sure if they're right for the job? what do you think? are they worth a gamble?
Is there anything else I should be considering?
