Which fixing? 3x3 post to a wall
milkman
14 Sep 2006
Hackney, London
Does anyone have any pointers on attaching a 3x3 fence post to a wall? I figured I should use stainless fixings as its exterior but can't find anything long enough (about 150mm needed?)
Any ideas?
Marko
I'd use Rawlbolts - you can replace the bolt with some threaded rod to get whatever length you need.
Cheers :wink:
Paul
Cheers :wink:
Paul
That is a shield anchor, is it not?
Ed
EdSutton":2p9qdrn7 said:
Cheers :wink:
Paul
Ed
Rawl bolts are so last year chaps- You want a thunder bolt-
http://www.fwb.co.uk/mall/productpage.c ... 3MMA/63637
Drill the hole through the post straight into the masonry and wind it in with a big spanner or socket set. They are superb and ***** proof. The bolt is slightly larger than the hole eg If it's an M10 bolt drill a 10mm hole and it the cuts a thread into the masonry when screwed in.
HTH
I'm with Matty! They are the best thing since they started putting wind in wheels!
Roy.
I agree Matty. I used Spax RA when lining my workshop. Screwed straight into a hole in reconstituted stone without a problem. Halves the time attaching battens to a wall. Much simpler.
Boz
EdSutton":3lmdedza said:
Cheers :wink:
Paul
Ed
Maybe - I call them Rawlbolts :)
Cheers :wink:
Paul
Mattty":2su5r40n said:
EdSutton":2su5r40n said:
Cheers :wink:
Paul
Ed
HTH
I take it these are basically the same as Tapcons are they?
Ed
EdSutton":3iex2rur said:
Cheers :wink:
Paul
Ed
HTH
Ed
Do you have a different name for every fixing? :lol:
Dunno mate never heard of Tapcon's..they sound like a female sanitary product :roll:
Looks that way doesn't it...not trying to be an arse honestly.
I have always known the type of fixing you describe as a Tapcon, this seems to be what they're called on all the construction sites I've worked on over the years.
Ed
EDIT - http://www.tapcon.com/
Milky,
When I last did this job. I used a forstner bit to drill approx halfway through the post and then used heavy duty screws which did not need to be quite so long. You can always plug the holes if need be.
Another idea to add to the list.
Cheers, Tony.
You guys are talking complete rubbish, this is clearly a job for GripFill :roll:
:lol:
yeah i thought about 100mm stainless hammer fixings but felt leaving only leaving maybe 30mm of timber might be a bit weak. mind you its only fence panels so it probably would have been fine. theunderbolt thingrys look the ticket
What Matty said :D
I used the thunderbolt jobbers to hold a 3x3 on my garage wall and the sliding door hangs off them - no problem.
umm, if you do the forstner drill to sink the bolt heads thing - dont use a bit bigger than the bolt head. Use a bit bigger than the socket that you will use to tighten the bolt. :oops:
Another option is studding with injection resin. That's what I used to fix 90x90 posts to brick uprights in order to hang my garden gates. It works well.
Misterfish
Really depends on the quality of the masonry you want to attach to. If its friable, flaky or soft (eg victorian brick and horse hair mortar) then I would vote for resin and studding personally. If its recent blockwork or good solid brick then go with the thunderbolt.
Steve
