which detail sander .........
mark king
29 Apr 2009
......would you suggest.
I like Bosch as a manufacturer and would prefer to go battery driven for ease of use. I would also want it to be a hook & loop system too for pad replacement.
anyone know if there are any good offers on that might swing me onto them???
NickWelford":2mc9guth said:
Fein Multimaster
Do you mean the standard triangular pads that come with the saw or the extra sanding accessory set? While I agree 100% that the triangular pads are the bees knees - as is the Fein in general - but have to say I was underwhelmed by the sanding accessory set. Fiddly to use. Paper kept slipping out.
It's mains powered but have you considered the Bosch PMF180E multi-tool - it has a detail sander fitting but can also be used with saw blade attachments for flush sawing.
I must admit I would be interested to hear what the little profile sanding addition to the Fein is like - is this what you are talking about? It seems to take normal sanding paper folded over a profile and clamped to secure. I would use it for sanding in between architrave and the like. Anyone have any ideas?
Jonesy - the fein is the original PMF180E gadget. It is the same sort of thing but a bit better (lets see what that does!! :wink: )
Thanks all
Neil
