My current setup is on a frame held on Toughbuilt saw horses. I use it to make stuff for my new workshop (on ice until timber prices normalise). I also built our green house timber frame on it this year using the dogs and clamps to hold pieces as I cut and glued joints. It's main task will be to help me dimension the sheeting for the new workshop, after that I will reduce it to two sheets with the other two on a fold down frame.
I bought my tops from CNC Design (excellent service and incredibly well packaged to avoid damage). I use Benchdogs Quad Dogs which are excellent and have recently bought a Fence System Mk11 for repeatable cuts. I have a Triton Tracksaw with a 1500mm track and also an Evolution 2800 system which is ok but not as well made as the Triton which gives a more useful extra 100mm on cross cuts can be used with UJK dog rail clips from Axminster which hold the fence hard against the dogs.
It all works very well and is very accurate. I echo the advice to watch all of Peter Millard's Youtube vids to garner some very useful advice. I don't have the rail square but the newer model looks good. The challenge is that mfts are a rabbit hole that can become expensive, so my advice would be to watch as many Youtube videos on the subject and decide what will best suit you. Bear in mind that the parf system requires chamfered holes but you can buy a very good and cheap chamfer tool from Axminster if you prefer the parf system.
I hope this helps but shout up if you have any questions
View attachment 118900View attachment 118899
