Still there in Manchester waiting to be snapped up at only £695!
https://www.ebay.co.uk/itm/12456553...:dtQAAOSwatdgIcVa&LH_BIN=1&LH_ItemCondition=4
New fence and vfd and blade likely all that's needed,
A practical solution for one who has only a 13a household supply,
but needs a good machine that won't trip the breaker,
which one might be pushing with a 16" saw with a 2hp motor, as its the split second starting draw on the machine which uses the juice,
and the VFD/inverter has easily adjustable to suit, soft start capabilities to run a 24" no bother at all.
Even on my 100 quid cheapie, I have all the features I need.
This machine would do most of what a tablesaw does compared to a wee machine your looking at, which wouldn't be up to the task of anything more that cutting a few wee curves or making very short boxes.
It can take a 3/4" blade or larger which has enough 'beam strength'
to not need rely on a thrust guide for keeping it in position.
This means the machine can run without
using the thrust guide constantly, so its use is only for brief periods where you are pushing too fast, and the noise goes away.
Interchangeable guides can be replaced if needed on the Centauro CO600, but you don't need anything but a single thrust guide with this machine.
Compare that with a lesser machine, and you will likely see screaming thrust guides, if you look for some clip where that's not cut from the video, or sped up with music added.
That's meant to be the interesting part of the video, where you get to see the machine working
honestly.
Just my 2 cents, and might be of interest to some if not yourself.
Tom
