I've got an old wobbly four-legged stool which I've dismantled and cleaned up.
The holes are pretty worn from years of wobbling so I need a glue which will gap-fill and set as slowly as possible since I'm a beginner and there are twelve glued joints and four wedges to set.
I've got Evo-Stik Resin W, Titebond Hide glue (the ready made one in a bottle) and Lumberjack 5 minute PU glue.
Now The PU glue is out, I need more than five minutes to panic when I try to glue this up -
I believe that the hide glue is slower than the resin W so would that be the best option? Would hide glue be strong enough for a stool's heavy use? Or would I be better off buying a two-pack epoxy to use?
Martin.
Martin.
