Where to get 190x24 saw blade?
blackbulldog
6 Aug 2018
Corby
Hi,
Cleaning out the garage this week and found an old circular saw I'd bought from b&q years ago. Still seems to work ok but the blade is knacked. Blade size is 190 X 24 bore.
I've searched online but can't find anywhere selling that size.
Anyone know if that size is still for sale in UK?
I guess its a Performance Power saw bought from B+Q, any of the saw blade bore reducers will do - I would go for the Bosch as it should be well made.
So you will be ordering a new blade - before you order make sure the outside diameter of the blade is the same as existing blade (so it will fit inside the safety guard) and check the thickness (of the new blade) is the same (not thicker) than the Bosch reducing ring.
