where can I get plans for this project?
crackerjack
6 Nov 2009
Notts
Hello there
I want to make a table to go in the entrance hall in our house. It will be fairly small and will have a single drawer just under the table top (to put keys in and wife's lipsticks probably!).
My question in is there a book which has plans to build this kind of thing or something similar I can adapt?
Does anyone have a book on furniture which shows you how to build this type of table? What is the book called?
Doesn anyone have a link to free plans for this kind of table on the net?
All best, Jack
A really excellent book is "Illustrated Cabinet Making" by Bill Hylton
It covers the construction details of a large number of furniture items, usually offering three different styles in each. It does not however teach joinery techniques (eg how to cut a dovetail) if you need that sort of information you will also need additional instructional material.
I tend to work on similar lines to Brad, but as I smoke roll ups I use the inside part (white) of my rizla packet. Down side, you do need a sharpe pensil for finer detail.
Hi,
Knock up a softwood mock-up put it in place and if you like it make it from hardwood using the mock up for dimensions, using joints instead of screws.
I agree with Chris that this is an indispensible book, along with "Practical Design Solutions and strategies" isbn 1-56158-344-8
BradNaylor":2yr2e91b said:
Plans?
:shock:
Take the back of one envelope or fag packet, a stubby little pencil from behind your ear, and draw a little picture of what you want.
Then start cutting wood up.
Works for me...
That works...'cept when you (read I) gets it wrong, then it's expensive :evil:, the model idea is an excellent one and is recommended by Alan Peters - Rob
You could go somewhere between the fag packet and the full mock-up; occasionally when I can't quite picture the proportions of a piece (sounds like I make fine furniture, I don't, just cabinets and built in units and the very occasional nice thing) or how the space will change once the piece is in place, I've cut a cardboard box to the dimensions I've got in mind, even a flat piece of card will tell you if a table top is too big or too small.
Cheers,
T
many many thanks
just ordered a few of the books recommended. Should find what I need in them!!
Ta, Jack
and me - only because i dont smoke i generally draw it on a scrap bit of mdf
then swear loudly when i forget that ive drawn on it and put it in the burner by accident ](*,)
on the very rare occasion when scribble doesn't cut it I might use sketchup but i cant think of anything worse than working to plans drawn by someone else - even with the maskery jigs i'm going to be more "inspired by" than working directly off steves pdf
Racers":3u6omrif said:
Hi,
My bed and the telephone unit are both at stage 1 after many years to the point where it's now the family joke that any other request leapfrogs those getting made in 'real' wood!
oddsocks":37fvsr11 said:
Racers":37fvsr11 said:
Hi,
That's not so bad, my full size cardboard mock up served as a worktop/clutter magnet for months! At least it proved it's purpose to a sceptical partner.
T
