When is a Disston saw not a Disston saw?
Bod
18 Nov 2013
Wiltshire.
Having just acquired 2 Disston D-8 saws, both with problems.
One has been sharpened to the end of reasonable use, but has a Thumbhole handle.
The other is a 1950-55 horrible handle.
The blades won't swop, first is (was) a 28 inch rip, the second a 20 inch panel saw.
If I replace the first blade, with say a 26 inch cross cut, unmarked blade, would I still have a Disston?
Same with the second, replace the handle, possibly homemade, not following a Disston style, is it still a Disston?
Value wise, they both cost less than a fiver.
Bod
no, but you would have 2 usable saws. To be honest, you aren't going to negatively affect the value!
It's whatever you want to call it. The golden era disstons had good taper and tension. Something from the 1950s may not have. The thumbhole rip handle is designed for a heavy plate with a lot of tension, and even a crosscut saw of almost the same size will have a thinner plate and maybe less tension (save the thumbhole rip handle for a plate of similar type.
When you say "unmarked blade", what are you going to use?
It'd be my suggestion to set the thumbhole rip handle aside until you see a thumbhole rip with a broken handle, and reprofile the handle on the second saw. In my opinion, the plate is the valuable part of a saw, the core part that takes skill that's not common.
if you intend to use the saw once re handled/bladed then I see no problem. If you intend to sell it on as a pucka Disston then that raises questions which end up with you are at risk
Update.
The second saw, after reading the FAQ's on the Disstonian Institute website, it appears its even worse than I thought!
The blade is etched Henry Disston D-8, but the medallion is HK Porter era, post 1955, explaining the very poor handle shape.
Old stock blade fitted to new handle, I can do nothing that will not improve it!
Bod
To me the name follows the critical part of a tool. The part that makes a difference between good and bad. That is the saw blade on a saw. Handles tend to break and new replacements may be made once or twice in the life of a good saw.
I would not dismiss an old saw blade until I have tested it. It seems like the old time makers had a pretty uneven steel quality to start from and occasionally a low end maker could yield a good batch.
As others have said the thumbhole handle was intended for a long and wide blade. 28 or 30 inches long. A coarse crosscut saw of that size is very practical for log building and timber framing. I use a 28 inch Disston number 7 and I would never want to be without it. A coarse rip saw of that size is practical for the occasional odd riop cut that would be unpractical to do on a machine.
Either you need to find an old blade with a bad handle. You are not likely to find one and if you find one it isn't likely to fit. Or you could try to find a suitable piece of steel and make yourself a new blade. The saw won't be a Disston anymore but if you do your homework properly and manage to find a good piece of steel to start from you will get a migty fine saw!
