GrahamRounce":xma0jori said:
Is the main drawback likely to be how long it lasts or how well it works?
The latter in all probability, but then I'm probably the wrong person to ask that of
What is "blade drift" - sounds a bit ominous?
Blade drift is where the blade twists in the cut meaning that the blade is no longer parallel to the rip fence. The reasons are as follows:
Blade with extra set to one side - frequently a by-product of using a blade to cut curved pieces then trying to straight-line rip with the same blade. The answer is to keep a separate blade for ripping.
Inability to tension blade adequately or tension too low. A major bugbear with smaller saws. Just because a manufacturer claims that a saw will take a 3/4in blade doesn't mean it can tension that blade! It means that the machine will probably tension a 1/2 or possibly a 5/8in saw blade, and preferably a thin bodies one as opposed to the 0.040in bimetallic monster your friendly local ironmonger is trying to sell you. So with smaller saws go for thin carbon blades and take the manufacturers spec, with a pinch of salt, as well as regarding his tension gauge readings as suspiciously low
The blade is worn out. Bandsaw blades don't last forever so don't try to make them last for years. Blunt blades will drift
The blade is very narrow. Below 1/2in wide can be all but impossible to cure blade drift because the body of the blade is not going to give you a great deal of support in the cut. Conversely 3/4in blades and above suffer from very little blade drift
Even if a saw/blade combination does drift it is often easiest to deal with the problem by simply adjusting the rip fence to compensate for the drift or using what is called a point contact rip fence
The other thing to say is take the manufacturer's blade, the one supplied, fold it up and bin it. Then go and buy a decent quality blade and set the guides up properly - it can make a world of difference to the smallest of saws.
Hope that helps explain it. Good luck with your purchase.
Scrit
