You don't have to flatten the face of a spokeshave blade.This white powder on the stone when flattening the back of a new Stanley spokeshave cutter?
Could it be it residue spillover from the etching at the top (STANLEY)? Or some unwanted anti-patina/oxidiser?
Thanks Oracles
View attachment 157262View attachment 157263
Not to let it stand in the way of a good flattening!
In fact, why not point out he doesnt need a spokeshave? An axe would do, or failing that, just chew the wood down with his teeth? Unless he has dentures i guessYou don't have to flatten the face of a spokeshave blade.
It's just another modern sharpening ritual.
Ahhhh. We dont get these luxury add_ons in the u.k. i feel cheated now, the amount of mdf skirtings i could have scribed in with my face, saving me the need to buy a jigsaw.baldkev. Little known fact is our dentists can supply specialty dentures. Like flat top ones for chewing hides to make them soft. Popular with the native community. Hole punch ones for gasket making. Mechanics love those. Woodworkers can get beaver choppers. They have little blades with chip breakers so they can be removed for sharpening or changing to scrub, low angle, high angle (tropical hardwoods) and skewed. To be honest I think the added cost of multiple dentures is worth it for fast changing rather than switching blades.
It's just that flattening is a bit of an obsession - often not necessary, sometimes a positive disadvantage e.g. most new chisels arrive with slightly hollow flat side which actually makes sharpening very easy...etcIn fact, why not point out he doesnt need a spokeshave? An axe would do, or failing that, just chew the wood down with his teeth? Unless he has dentures i guess
It's true that you wouldn't use a spokeshave to take a blades width pass and attempt to use it like a no4, but equally, as it only takes a minute with a diamond setup, it certainly wont hurt.......
Block plane is made for exactly that sort of job. Better than spokeshave or chisel, except where you can't get a block plane in.although I've previously found putting some time into the flat cheek any single bevel blade - e.g chisel ground / japenese style kitchen knives etc seems to help greatly in refining the cutting edge. once it has been done to coarse grit to get consistency along the back, I can then just knock the wire edge off from future sharpening with just one or two light passes on a higher grit stone. it makes sense to me as the factory grinding marks are so coarse that what would the point be of sharpening the bevel side to anything med-fine if the obverse side is effectively serrated under the loupe? appreciate perhaps not the entire back of the cutter but it's so small and easily done it's barely any extra work and perhaps helps the bedding a little...
anyway not used one before and was keen to experiment. am trying to knock the sharp edges off the frame, this was something I'd forgotten to do before assembly so I've alternated between a chisel, the spokeshave and a block plane to start doing this. good learning for end grain work and finer chisel work.
View attachment 157291View attachment 157292
Yes, like Japanese chisels so you only have to keep the first 3 or 4mm flat, but some comments are like that obsession.... often not necessary, sometimes a positive disadvantageIt's just that flattening is a bit of an obsession - often not necessary, sometimes a positive disadvantage e.g. most new chisels arrive with slightly hollow flat side which actually makes sharpening very easy...etc
Yes I know it's boring but it comes up as regular as clockwork.Yes, like Japanese chisels so you only have to keep the first 3 or 4mm flat, but some comments are like that obsession.... often not necessary, sometimes a positive disadvantage
