Rob Cheetham
Great build there @eribaMotters. This is what I aspire mine to be like tbh lol. Just a few questions if you dont mind me asking.I used 150 mm tanalised featheredge fixed with 50mm sheradized lost head nails. Board overlap was about 30mm, different on end to sides so as to get site lines around openings. Thin edge 6mm, thick edge 18mm. This was onto a 4 x 2 studwork that was wrapped with felt, insulated with rockwool and lined with 10mm ply. I did this over 20 years ago and would repeat the method but probably with an air gap behind the featheredge. The shed is 8x5m.
ColinView attachment 110419View attachment 110420
* What roof pitch did you to for the roof and how high did you go for the top plate of the walls?
* What did you use for the trim around the doors, windows, conrers etc as it looks great?
* For all the trim did you fix it ontop of the cladding or did you fix it first then but the cladding up to it?
* What roof did you go for as it looks really top quality.
* Any tips on fitting of pvc doors and windows to timber frame as im looking at fitting a pvc door and window
Sorry if thats alot to ask as I know you said you did it 20 years ago so may not remember but any help will do. I cant believe its 20 years old. Looks brand new still
Thanks in advance and once again, great build
