Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
Hiding to nothing, I fear.ChrisMcBride":8k4mpy6o said:I might try the clutched core drill option just to finish it off by hand with the forstner and then see about investing in a pillar drill once this one is finished.
You've picked the hardest material (almost), and given this used to be a keel block, it's probably got all sorts of inclusions - grit, iron/steel filings, etc. All of which will wreck your Forstner bit (which must have been seriously expensive if it's a reasonable one at that diameter).
I've been mulling over this. I wonder if a modified TCT core drill might do it.Another question in regards to this project. If I decide when making my next one (I have the other half to this keel block) that I want to cut through holes rather than blind, what is the best way to cut through at least 30cm of solid oak 85mm wide? I'm looking for time saving efficiency here if this is to be a commercially viable option.
You can easily get the depth that way, and the core shouldn't get too stuck (If it does, drive a few big woodscrews in, Mole grips and PULLLLL!). There are some very nice people at my local Leitz sharpening centre - You might find someone locally who can re-grind the tip profile to be more suitable for wood. You might also need to relieve the supporting steel cylinder: making U-shaped holes in it ahead of the tips, analogous to the gullets of a normal saw, to take the sawdust.
Advantages: deep enough for the whole through-cut, shouldn't clog as much as a normal holesaw (wider kerf), cleaner cut (if you get the tip/tooth profile and speed right), nice finish (clean up wth a Carroll drum sander).
Disadvantages: needs power and decent RPM (wider kerf), almost certainly a BIG drill press (for SAFETY as well as usability - it'll be one hill of a saw!), expensive because of the modifications (make at least two of them once you get a good design), slow if you can't eject the cores easily (you'll only find out in use).
It will work pretty well on a bandsaw with a resaw blade, BUT see comments about inclusions above - don't expect long blade life! Fettle the bandsaw, fit a sharp blade (from Tuff Saws - take Ian's advice on choice of blade) and go for it. [edit] Because of the look (you want to keep this, I assume), you might need a resaw frame/carriage too (make one), so that you can make the block slide smoothly in one axis to get a clean, straight cut (and probably for safety, too).I don't think cutting it in half and re-glueing back together is an option as it is so heavy, it weighs a ton.
There's an obvious reason: nobody does it like that! Big holes are usually mortices and thus rectangular. That's why there are things like chain morticers for timber framing.I see that there are long length wide diameter masonry core drill bits for brick/concrete walls but no wide diameter long length hole core drill bits for wood.
If you are doing this seriously, have a look at modifying TCT masonry holesaws. They may be getting harder to find as diamond ones are ubiquitous now (and far cheaper than when I bought mine, grrr.), but you ought to get something to suit.
I really am no expert, but I can't see how you can achieve this without a significant investment in custom tooling of some sort, and/or modifying the design to help you in construction. It's simply too unusual otherwise.
E.
Afterthought: It's a keel block - you must be near a shipyard! Are there any old shipwright's tools that might do it? I'm still struggling to think of a marine application that would need such a hole, but there might have been something. Perhaps that's worth a bit of research. Ask a question over in the Hand Tools section.
PPS: On getting the cores out: say you have six teeth on the saw. before you make the big hole, drill six relieving through-holes in the waste, touching the circumference (say half-inch diameter). They'll take a lot of the sawdust in use, making a faster and cleaner cut, and, once done, you should only need to align the holes with the saw tips, for the core to slide out easily. THIS WILL NOT SAFELY WORK WITH A HANDHELD DRILL. The vibration as the teeth drop into and out of the holes will be a killer. (perhaps make four holes first and the last two when you're almost through?).
