My question is this: Is 'construction veneer' just a sheet of 1.5mm thick, good quality veneer? Or does it mean something else entirely?
Reason for asking:
I find myself needing to create a bunch of curved panels for an oval baby crib/cot. The largest panels will be around 21" wide by around 27" tall, and I'd like them to end up around 1/2" thick. Radius will be 14 1/4".
(533mm wide x 568mm tall x 12mm thick)
The panels need to have high quality maple on both sides when they're done. Robbins Timber in Bristol has something called 'Construction Veneer' that is 1.5mm thick. If I use that, I figure the panels can have 5 layers - 3 sheets of 3mm baltic birch plywood in the middle, sandwiched between a layer of the maple construction veneer.
Another option: They do have 4mm maple veneered plywood - though 4mm is getting thicker then I'd like when it comes to bending. Also, I figured more layers would equal more strength and stability as well as less springback.
Here's a pic of a sketchup model I made of the project for illustrative purposes:
Reason for asking:
